HomeKit automation brightness value problem
(19.03.2024, 10:00)Daniel Wrote: You can log the objects you are controlling and then you will see what values were sent, if they are correct then problem will be on KNX side. Maybe you need to correct some datatypes on objects from uint to scale
Values in LM5 objects paragraph sending correctly, i'll attach photo with two examples, when automation set lights correctly, and when not.
(19.03.2024, 10:03)admin Wrote: Which device mode are you using - Light Brightness or Light On/Off Brightness?
I'm using Light On/Off Brightness
RE: HomeKit automation brightness value problem - by Mantas - 19.03.2024, 19:08
