chartist to display nice pie...
#27
Thanks for your lp file.
I tried to do sum of the value, but can't get length value, still 0 for result. however I can see the result value as array type in console...
I tried lots of solution with each, for... without success. Any idea ?
function readTrend( listeId, dayBefore, dayBase ) {   var data = JSON.stringify({     dates_curr: {       start: getdate(dayBefore),       end: getdate(dayBase)     },     ids: listeId,   });   var result = [];   var totVal=[];     $.post('/scada-vis/trends/fetch', { data }, function(trends) {     trends = JSON.parse(trends);     $.each(trends, function(_, trend) {       result.push(trend.data);     });   });     return sum(result); }
function sum(array) {   //test each   let totVal = 0   console.log(array[1]);   let newArray=new Array();   newArray=array;      $.each(newArray, function(_, lined) {       console.log(lined.data);     });   // test for for (let l = 0; l < array.length; l++) {    console.log('hello');    var sum = 0;     for (let k = 0; k < array[l].length; k++) {         sum += array[l][k];     }     //console.log(sum);    totVal.push(sum);     }       return sum(result); }
result array in console log. Also result[0] or result[1] or result[0][0]...don't work.
Array [] ​ 0: Array(24) [ 112, 112, 114, … ] ​ 1: Array(24) [ 291, 173, 666, … ] ​ 2: Array(24) [ 13, 14, 13, … ] ​ length: 3 ​ <prototype>: Array [] scada-vis:771:11
only solution I found is using inside the function
function readTrend( listeId, dayBefore, dayBase, total ) {   var data = JSON.stringify({     dates_curr: {       start: getdate(dayBefore),       end: getdate(dayBase)     },     ids: listeId,   });   var result = [];   var totVal=[];     $.post('/scada-vis/trends/fetch', { data }, function(trends) {     trends = JSON.parse(trends);     $.each(trends, function(_, trend) {       if (total>0) {         let totVal = 0         for (let l = 0; l < trend.data.length; l++) {            totVal += trend.data[l];         }           result.push(totVal);               } else {         result.push(trend.data);       }     });   });     return result; }
However I can't understand why in the other solution the lenght and [x] don't work
SE ECO EXPERT
chartist to display nice pie... - by domotiqa - 05.01.2022, 08:56
RE: chartist to display nice pie... - by jmir - 14.02.2022, 11:32
RE: chartist to display nice pie... - by jmir - 14.02.2022, 13:34
RE: chartist to display nice pie... - by jmir - 15.02.2022, 11:15
RE: chartist to display nice pie... - by Acla - 12.06.2023, 05:05
RE: chartist to display nice pie... - by JRP - 08.09.2022, 16:18
RE: chartist to display nice pie... - by Acla - 12.06.2023, 15:44
RE: chartist to display nice pie... - by jmir - 25.03.2024, 14:49
RE: chartist to display nice pie... - by domotiqa - 27.03.2024, 09:14
