06.04.2024, 10:10
- Which firmware version are you using?
- Are you connected directly on the same network or externally (VPN, ZeroTier or port forwarding)?
- When the web server is not responding can you still ping LM? Check system uptime in System config > Status > System status. Maybe LM is rebooted when this happens.
- Try this script and see if it helps: https://forum.logicmachine.net/showthrea...7#pid23987
- Check for any errors in /var/log/nginx/error.log
