LM Home app (Andrоid/iOS starter)
#43
(07.05.2024, 13:09)Daniel Wrote: This is a new version of our LM Home app where we added ability to add more than one LM to the app.
To add more than one LM do a long press on LM Home app icon on your mobile and select Add LM. You will see new search window to select which LM should be added. If there is only one available then LM login page will be added.
If you use remove LM button then you will see screen with all added LMs and you will have to select the one to be removed.
Clear config will delete all LMs.
Please test and feedback is more than welcome
https://dl.openrb.com/misc/lmhome-20240507_3.apk
Hi Daniel and thanks for your work. Before install new version is it better uninstall the before version?
Best regards Cristian
LM Home app (Andrоid/iOS starter) - by admin - 30.01.2024, 10:58
RE: LM Home app (Andrоid/iOS starter) - by CristianAgata - 07.05.2024, 14:04
Error LM Home app (Andrоid) - by stawros - 12.08.2026, 06:03
