17.07.2024, 07:18
Most likely storage is corrupted.
Which hardware version do you have? There are different hardware versions of LM2. First one with an ethernet port in the middle and a separate USB ports. The second one has an ethernet port on the right combined with a single USB port. The first one has a built-in storage chip which means that data recovery is most likely not possible. The second one uses a micro SD card where some data might be recoverable.
