SOS cloud sync doesn't work!!!
Run this script and see the logs
function checktcp(ip, port)   local sock = require('socket').tcp()   sock:settimeout(1)   local res, err = sock:connect(ip, port)   sock:close()   return res, err end -- change IP/PORT as needed res, err = checktcp('remote.logicmachine.net', 443) if res then   log('connect OK') else   log('connect ERROR', err) end
SOS cloud sync doesn't work!!! - by almoisey - 31.07.2024, 07:09
RE: SOS cloud sync doesn't work!!! - by Daniel - 31.07.2024, 07:50
