reactor modem check
hi
I have two reactor lm5p2-lte that with a storm stopped seeing the SIMs, in one the SIM had signs of burning, now when I try to use the script to verify the modem it tells me init script failed in both, the 2 modems could be damaged
for check the modem i use this script
apn = 'PUT_YOUR_APN_HERE' dial = '*99***1#' io.writefile('/sys/class/gpio/export', 8) io.writefile('/sys/class/gpio/export', 71) io.writefile('/sys/class/gpio/gpio8/direction', 'high') os.sleep(1) io.writefile('/sys/class/gpio/gpio8/direction', 'low') io.writefile('/sys/class/gpio/gpio71/direction', 'high') tty1 = '/dev/ttyACM3' tty2 = '/dev/ttyUSB2' for i = 1, 20 do   os.sleep(1)   if io.exists(tty1) then     tty = tty1     break   elseif io.exists(tty2) then     tty = tty2     break   end end if not tty then   log('init failed')   return end buf = {} function send(cmd, timeout)   port:write(cmd .. '\r\n')   local res, err = port:read(1000, timeout or 1)   return res, err end function sendlog(cmd, timeout)   local res = send(cmd, timeout)   if res then     buf[ #buf + 1 ] = res   end end port = require('serial').open(tty) log('open port', tty) for i = 1, 20 do   res = send('AT')   if res then     break   end end if not res then   log('no response')   return end sendlog('AT&F', 10) -- reset settings sendlog('ATE1') -- echo enabled sendlog('AT+CGDCONT=1,"IP","' .. apn .. '"') -- set apn sendlog('ATD' .. dial) -- connect res = table.concat(buf) log(res)
reactor modem check - by Frank68 - 21.08.2024, 13:10
RE: reactor modem check - by admin - 21.08.2024, 14:03
