MQTT Client app
UPD: i moved all my rules to the new application (54 total) Smile hope it won't break anything :-D
so regarding throttle, the following approach seems to be working, with the knowledge that i should use unique names per each script
"In" event:
ls_bedroom_throttle = ls_bedroom_throttle or require('user.mqttclient_common').throttle(60) local data = json.pdecode(payload) if type(data) == 'table' then   return ls_bedroom_throttle(data.illuminance) end
user library:
return {   throttle = function(timeout)     local last_update = 0     return function(val)       if(val ~= nil) then         local now = os.time()         if((now - last_update) < timeout) then           return nil         else           last_update = now           return val         end       end     end   end }
SUGGESTION:
1) in error log make it obvious which script contains error, so i can fix it easily. For example this error does not have information where to look:
Quote:error: failed to run script - [string "in-26"]:9: attempt to compare nil with number
2) output errors in global error log so they can be noticed in time
MQTT Client app - by Daniel - 10.09.2024, 14:12
RE: MQTT Client app - Beta testing - by myg - 23.09.2024, 08:58
RE: MQTT Client app - Beta testing - by myg - 23.09.2024, 09:50
RE: MQTT Client app - Beta testing - by admin - 23.09.2024, 10:04
RE: MQTT Client app - Beta testing - by myg - 23.09.2024, 10:41
RE: MQTT Client app - Beta testing - by myg - 23.09.2024, 12:50
RE: MQTT Client app - Beta testing - by myg - 01.10.2024, 09:37
RE: MQTT Client app - Beta testing - by admin - 01.10.2024, 12:53
RE: MQTT Client app - Beta testing - by myg - 01.10.2024, 13:11
RE: MQTT Client app - Beta testing - by cekca - 02.10.2024, 08:18
RE: MQTT Client app - Beta testing - by admin - 02.10.2024, 08:18
RE: MQTT Client app - Beta testing - by cekca - 02.10.2024, 08:29
RE: MQTT Client app - Beta testing - by admin - 02.10.2024, 08:40
RE: MQTT Client app - Beta testing - by AEK - 02.10.2024, 08:48
RE: MQTT Client app - Beta testing - by admin - 02.10.2024, 09:19
RE: MQTT Client app - Beta testing - by cekca - 02.10.2024, 12:58
RE: MQTT Client app - Beta testing - by admin - 02.10.2024, 13:00
RE: MQTT Client app - Beta testing - by cekca - 02.10.2024, 13:07
RE: MQTT Client app - Beta testing - by admin - 02.10.2024, 13:08
RE: MQTT Client app - Beta testing - by cekca - 02.10.2024, 13:11
RE: MQTT Client app - Beta testing - by admin - 02.10.2024, 13:37
RE: MQTT Client app - Beta testing - by admin - 11.10.2024, 10:52
RE: MQTT Client app - Beta testing - by myg - 14.10.2024, 08:05
RE: MQTT Client app - by admin - 16.10.2024, 07:46
RE: MQTT Client app - by myg - 17.10.2024, 12:13
RE: MQTT Client app - by admin - 17.10.2024, 12:36
RE: MQTT Client app - by Snoolik - 06.11.2024, 15:10
RE: MQTT Client app - by antony.19 - 04.12.2024, 23:08
RE: MQTT Client app - by admin - 05.12.2024, 09:49
RE: MQTT Client app - by antony.19 - 05.12.2024, 18:33
RE: MQTT Client app - by admin - 11.12.2024, 10:18
RE: MQTT Client app - by LKBA - 16.01.2025, 08:23
RE: MQTT Client app - by admin - 16.01.2025, 14:01
RE: MQTT Client app - by LKBA - 16.01.2025, 14:09
RE: MQTT Client app - by admin - 16.01.2025, 14:10
RE: MQTT Client app - by myg - 16.01.2025, 19:01
RE: MQTT Client app - by admin - 17.01.2025, 07:54
RE: MQTT Client app - by myg - 19.01.2025, 16:57
RE: MQTT Client app - by Pierluigi - 28.03.2025, 12:59
RE: MQTT Client app - by Daniel - 28.03.2025, 13:02
RE: MQTT Client app - by Pierluigi - 28.03.2025, 13:03
RE: MQTT Client app - by admin - 28.03.2025, 13:03
RE: MQTT Client app - by admin - 28.03.2025, 13:11
RE: MQTT Client app - by Pierluigi - 28.03.2025, 13:14
RE: MQTT Client app - by tomnord - 24.04.2025, 12:09
RE: MQTT Client app - by admin - 24.04.2025, 12:25
RE: MQTT Client app - by tomnord - 27.05.2025, 13:41
RE: MQTT Client app - by tomnord - 24.04.2025, 13:09
RE: MQTT Client app - by admin - 24.04.2025, 13:10
RE: MQTT Client app - by tomnord - 25.04.2025, 09:47
RE: MQTT Client app - by admin - 25.04.2025, 09:52
RE: MQTT Client app - by admin - 27.05.2025, 13:47
RE: MQTT Client app - by jmir - 30.05.2025, 16:07
RE: MQTT Client app - by admin - 02.06.2025, 08:21
RE: MQTT Client app - by jmir - 11.06.2025, 14:11
RE: MQTT Client app - by jmir - 13.06.2025, 07:00
RE: MQTT Client app - by admin - 13.06.2025, 07:39
RE: MQTT Client app - by tomnord - 17.06.2025, 09:14
RE: MQTT Client app - by admin - 17.06.2025, 10:08
RE: MQTT Client app - by batistacaceres - 19.06.2025, 08:24
RE: MQTT Client app - by admin - 19.06.2025, 08:33
RE: MQTT Client app - by batistacaceres - 19.06.2025, 09:03
RE: MQTT Client app - by myg - 30.07.2025, 07:36
RE: MQTT Client app - by Daniel - 30.07.2025, 07:40
RE: MQTT Client app - by myg - 30.07.2025, 08:20
RE: MQTT Client app - by Daniel - 30.07.2025, 08:32
RE: MQTT Client app - by peyoe - 05.02.2026, 11:37
RE: MQTT Client app - by Daniel - 05.02.2026, 12:24
RE: MQTT Client app - by jmir - 05.03.2026, 07:23
RE: MQTT Client app - by admin - 05.03.2026, 07:45
RE: MQTT Client app - by Fahd - 07.04.2026, 08:02
RE: MQTT Client app - by Daniel - 07.04.2026, 08:19
RE: MQTT Client app - by Fahd - 07.04.2026, 08:20
RE: MQTT Client app - by Daniel - 07.04.2026, 08:22
RE: MQTT Client app - by Fahd - 07.04.2026, 08:26
RE: MQTT Client app - by Daniel - 07.04.2026, 08:28
RE: MQTT Client app - by Daniel - 07.04.2026, 08:29
RE: MQTT Client app - by Fahd - 07.04.2026, 08:56
RE: MQTT Client app - by Daniel - 07.04.2026, 08:57
RE: MQTT Client app - by Fahd - 07.05.2026, 12:47
RE: MQTT Client app - by admin - 07.05.2026, 12:54
RE: MQTT Client app - by Fahd - 07.05.2026, 13:32
RE: MQTT Client app - by Fahd - 05.06.2026, 09:28
RE: MQTT Client app - by Daniel - 05.06.2026, 09:50
RE: MQTT Client app - by admin - 05.06.2026, 09:50
RE: MQTT Client app - by Fahd - 05.06.2026, 10:42
RE: MQTT Client app - by Daniel - 05.06.2026, 10:50
RE: MQTT Client app - by Fahd - 05.06.2026, 11:06
RE: MQTT Client app - by Daniel - 05.06.2026, 11:13
RE: MQTT Client app - by admin - 05.06.2026, 11:18
RE: MQTT Client app - by Fahd - 05.06.2026, 17:19
RE: MQTT Client app - by jacopo.berte - 19.10.2026, 09:04
RE: MQTT Client app - by Daniel - 19.10.2026, 10:01
RE: MQTT Client app - by myg - 22.10.2026, 18:51
RE: MQTT Client app - by admin - 23.10.2026, 07:18
