kOoO Test
"two in one" - you mean visualization (plan/element) settings + visualization parameters of objects? That would make sense since old visu export doesn't contain objects' visparams. Those would have to be either defaulted or taken from actual objects (during the transition period) if such import was supported.
But now regarding firmware upgrade (or import of old project backup into new firmware with new visu), new visu will be prefilled with data from old visu (+ object "visparams" settings) or will it be completely empty? Because in this case there should not be any problem with creating the new visu structure based on old data, right?
kOoO Test - by kOoO - 22.10.2024, 14:03
RE: kOoO Test - by Daniel - 22.10.2024, 15:15
RE: kOoO Test - by kOoO - 23.10.2024, 11:20
RE: kOoO Test - by Daniel - 23.10.2024, 11:28
RE: kOoO Test - by kOoO - 23.10.2024, 12:14
RE: kOoO Test - by Daniel - 23.10.2024, 12:48
RE: kOoO Test - by kOoO - 24.10.2024, 11:43
RE: kOoO Test - by kOoO - 24.10.2024, 13:23
RE: kOoO Test - by Daniel - 24.10.2024, 13:54
RE: kOoO Test - by kOoO - 25.10.2024, 10:55
RE: kOoO Test - by Daniel - 25.10.2024, 11:06
RE: kOoO Test - by kOoO - 25.10.2024, 12:00
RE: kOoO Test - by Daniel - 25.10.2024, 14:40
