LM Home app (Andrоid/iOS starter)
(17.02.2025, 08:00)admin Wrote: 1. Check that "Remember login and password" is enabled in LM > Users > User access settings. Don't use admin user for the app. Keep the app running in the background after the first login otherwise the credentials might not be saved.
2. Create a user library named push, provide user names, tokens and create groups as needed.
local tokens = {   ['User A'] = 'user-token-A',   ['User B'] = 'user-token-B',   ['User C'] = 'user-token-C', } local groups = {   ['Group A'] = { 'User A', 'User B' },   ['Group B'] = { 'User B', 'User C' }, } return function(name, title, body)   local push = require('applibs.lmcloud.push')   local token = tokens[ name ]   if token then     return push(token, title, body)   end     local group = groups[ name ]   if group then     local ress, errs = {}, {}         for _, tname in ipairs(group) do       token = tokens[ tname ]             if token then         local res, err = push(token, title, body)         if res then           ress[ name ] = true         else           errs[ name ] = err         end       else         errs[ name ] = 'not found'       end     end         return ress, errs   end     return nil, 'not found'  end
Usage:
push = require('user.push') name = 'Group A' title = 'Push title' body = 'Push message body' res, err = push(name, title, body) log(res, err)
Wow. Great! Thanks. Works like a charm.
LM Home app (Andrоid/iOS starter) - by admin - 30.01.2024, 10:58
RE: LM Home app (Andrоid/iOS starter) - by jerryhenke - 17.02.2025, 11:50
Error LM Home app (Andrоid) - by stawros - 12.08.2026, 06:03
