SMS not received
We are using a LogicMachine5 Reactor GSM to send SMS in case of alarm of some variables. The script uses a for to send the message to multiple numbers, with a delay between them. You can see the code below (I changed the phone numbers with generic ones for security purposes).
The problem is that not every SMS is received. What could be causing this? Is there any way to check if the SMS is received?
Thank you in advance,
André Neves
require('user.sms') Nrs_Tlf={'123456789',        '987654321',      '147852369'} tab = string.split(name, ">") if value==1 then     Alarme="Alarme:\n"..tab[2].."\n"..timestamp elseif (value==2) then    Alarme="Alarme Reconhecido:\n"..tab[2].."\n"..timestamp elseif (value==3) then    Alarme="Alarme Reposto:\n"..tab[2].."\n"..timestamp end if (value<4 and value>0) then     for i = 1, 3, 1 do       sendsms(Nrs_Tlf[i],Alarme)       os.sleep(30)     end   log("SMS enviados") else   log("Out of bounds.") end
SMS not received - by andrepneves@gmail.com - 20.03.2025, 14:49
RE: SMS not received - by admin - 21.03.2025, 07:59
RE: SMS not received - by admin - 26.05.2025, 06:11
RE: SMS not received - by admin - 26.05.2025, 11:56
RE: SMS not received - by admin - 26.05.2025, 12:30
RE: SMS not received - by admin - 26.05.2025, 14:20
RE: SMS not received - by admin - 03.06.2025, 12:27
