Neighbouring LM - Visualization
(13.06.2025, 07:57)admin Wrote: 1. Too big TTL value can lead to multicast looping if the network is not configured correctly. It should be the lowest possible value that works between networks.
2. Correct, it's for ZeroTier. So leave it blank for local network.
Just to make about the TTL Limit. With this installation; If RED LM needs to share objects with both other LMs will the TTL still need to be set to "2", hence there are 2 switches between the two LMs?
RE: Neighbouring LM - Visualization - by PolymorphedCust - 13.06.2025, 10:07
