Zigbee integration
(02.07.2025, 06:18)Daniel Wrote: It works with any imx6 version of LM
Ok, but I can't get the script to work. Are we supposed to add a user library for this?
Update: I always get the error message: "address must be a string or a number".
Here is my script:
local zb = require('applibs.zigbee') local ieee = 'f4ce36e12b9esa24' local cluster = 0x0B04 local endpoint = 10 local args = {   ieee = ieee,   endpoint = endpoint,   cluster = cluster,   attributes = { 'rmsvoltage' } } local res, err = zb.cmdsync('getnamedattributes', args) if type(res) == 'table' then   log('Zigbee-respons: ' .. json.encode(res))    if res.rmsvoltage then     log('Spenning (RMS): ' .. tostring(res.rmsvoltage) .. ' V')   else     log('Ingen rmsvoltage funnet i respons')   end else   log('Feil ved lesing: ' .. tostring(err or 'ingen respons')) end
Zigbee integration - by Alexander - 07.12.2024, 08:03
RE: Zigbee integration - by CristianAgata - 08.12.2024, 13:55
RE: Zigbee integration - by Alexander - 30.06.2025, 09:24
RE: Zigbee integration - by Daniel - 09.12.2024, 08:37
RE: Zigbee integration - by jurmaster - 13.12.2024, 08:19
RE: Zigbee integration - by Daniel - 13.12.2024, 08:37
RE: Zigbee integration - by Daniel - 30.06.2025, 11:05
RE: Zigbee integration - by Alexander - 01.07.2025, 07:33
RE: Zigbee integration - by Daniel - 01.07.2025, 07:37
RE: Zigbee integration - by Alexander - 01.07.2025, 07:45
RE: Zigbee integration - by Daniel - 01.07.2025, 08:04
RE: Zigbee integration - by Alexander - 01.07.2025, 08:09
RE: Zigbee integration - by Daniel - 01.07.2025, 09:56
RE: Zigbee integration - by Alexander - 01.07.2025, 17:18
RE: Zigbee integration - by Daniel - 02.07.2025, 06:18
RE: Zigbee integration - by Alexander - 02.07.2025, 07:17
RE: Zigbee integration - by RomansP - 02.07.2025, 09:48
RE: Zigbee integration - by Alexander - 02.07.2025, 11:07
RE: Zigbee integration - by RomansP - 02.07.2025, 11:56
RE: Zigbee integration - by Alexander - 02.07.2025, 12:12
RE: Zigbee integration - by Alexander - 02.07.2025, 14:27
RE: Zigbee integration - by RomansP - 03.07.2025, 08:44
RE: Zigbee integration - by Alexander - 04.07.2025, 08:15
