28.08.2025, 08:41
@linux_sun, can you explain what exactly is missing? If you want to send a fix Boolean value you should use Switch widget with Switch mode set to "Send On" or "Send Off". If you want to send a fixed numeric value then use the respective widget. The logic is different from Mosaic but the end result is the same.
