03.10.2025, 10:02
(02.10.2025, 18:44)Ozturker Wrote: I receıved below 422
Code:* string: Request body: {"commands":[{"capability":"switch","command":"on","component":"main"}]} * string: SmartThings response code: 422 * string: SmartThings response body: {"requestId":"391879646930462279","error":{"code":"ConstraintViolationError","message":"The request is malformed.","details":[{"code":"BodyMalformedError","target":"httpRequestBody","message":"The request body is malformed and cannot be processed by server.","details":[]}]}}
Here is the full code
Code:local https = require('ssl.https') local json = require('json') local ltn12 = require('ltn12') -- ️ put your smartthings pat here local token = '*************' local livingr_cam_id = '**************************' -- Camera KNX group objects (choose addresses as needed) local ga_cam_onoff_set = grp.create({ datatype = dt.bool, address = '33/4/1', name = 'Camera On/Off' }) local ga_cam_onoff = grp.create({ datatype = dt.bool, address = '33/4/2', name = 'Camera On/Off Status' }) local ga_cam_motion = grp.create({ datatype = dt.bool, address = '33/4/11', name = 'Camera Motion Detected' }) local ga_cam_sound = grp.create({ datatype = dt.bool, address = '33/4/12', name = 'Camera Sound Detected' }) local cam_set = grp.getvalue(ga_cam_onoff_set) -- Set local cam_set_status = grp.getvalue(ga_cam_onoff) -- Status -- Helper to turn camera on or off using a raw JSON string local function set_camera_onoff(cam_id, state) local cmd = state and 'on' or 'off' local body = require('json').encode({ commands = { { component = 'main', capability = 'switch', command = cmd, } } }) log('Request body: ' .. body) local sink_tbl = {} local res, code = https.request({ url = 'https://api.smartthings.com/v1/devices/' .. cam_id .. '/commands', method = 'POST', headers = { ['authorization'] = 'Bearer ' .. token, ['content-type'] = 'application/json; charset=utf-8', ['accept'] = 'application/json', }, source = ltn12.source.string(body), sink = ltn12.sink.table(sink_tbl), }) local response_body = table.concat(sink_tbl) log('SmartThings response code: ' .. tostring(code)) log('SmartThings response body: ' .. response_body) return res, code, response_body end if cam_set == true then if cam_set_status == false then set_camera_onoff(livingr_cam_id, true) end elseif cam_set == false then if cam_set_status == true then set_camera_onoff(livingr_cam_id, false) end end
Here is the working postman cURL
Code:curl --location 'https://api.smartthings.com/v1/devices/***************************/commands' \ --header 'Content-Type: application/json' \ --header 'Authorization: **********' \ --data '{ "commands": [ { "component": "main", "capability": "switch", "command": "on" } ] }'
Thank you for the support
Hi, try to add this in the header, for me works
['content-length'] = #body,
Best regards Cristian
