CANx DALI questions
Old DALI implementation is very limited - you can only control each ballast separately using on/off and scale objects. Everything else must be done using scripts.
KCD supports DALI groups (control of multiple ballasts), scenes, CCT/RGB/RGBW ballasts. You can change most of ballast parameters directly from the UI. It also supports DALI2 sensors and push-button inputs.
CANx DALI questions - by Novodk - 29.09.2025, 12:28
RE: CANx DALI questions - by admin - 29.09.2025, 12:38
RE: CANx DALI questions - by Novodk - 09.10.2025, 12:01
RE: CANx DALI questions - by admin - 09.10.2025, 12:08
RE: CANx DALI questions - by PolymorphedCust - 30.10.2025, 08:55
RE: CANx DALI questions - by AEK - 30.10.2025, 09:50
RE: CANx DALI questions - by PolymorphedCust - 30.10.2025, 10:32
RE: CANx DALI questions - by AEK - 30.10.2025, 13:34
RE: CANx DALI questions - by Novodk - 30.10.2025, 13:44
RE: CANx DALI questions - by AEK - 30.10.2025, 14:03
RE: CANx DALI questions - by PolymorphedCust - 05.12.2025, 05:56
RE: CANx DALI questions - by admin - 05.12.2025, 07:03
RE: CANx DALI questions - by PolymorphedCust - 05.12.2025, 07:55
RE: CANx DALI questions - by admin - 05.12.2025, 07:58
RE: CANx DALI questions - by PolymorphedCust - 05.12.2025, 08:05
RE: CANx DALI questions - by admin - 05.12.2025, 08:09
RE: CANx DALI questions - by PolymorphedCust - 05.12.2025, 08:17
RE: CANx DALI questions - by mariosp - 30.06.2026, 19:13
RE: CANx DALI questions - by Daniel - 01.07.2026, 10:32
RE: CANx DALI questions - by mariosp - 01.07.2026, 19:55
RE: CANx DALI questions - by Daniel - 02.07.2026, 07:08
