Modbus profile of LM internally supports ONLY uint16 registers without type switchin
I've tried a lot to get a specific Value from my modbus device into LM.
First I've created an Modbus Profile. For some of the values it works correct but some others deliver no values.
If I do a connection test with the Modbus Test Modul the correct value is delivered.
So I found out (with Chat GPT) that it seems the test modul and the profiles works different. Can you confirm?
Test Modul:
- reads raw data
- actively interprets (int16 / uint16 / int32 / uint32)
The Modbus profile ALWAYS interprets as uint16, no type selection and no sign switching and that seems the issue.
Please find the .json profile below. It's just the faulty address.
{   "product_code": "KWL_HBX_250_500",   "manufacturer": "HELIOS",   "name": "KWL_HBX",   "description": "LogicMachine Modbus profile for HBX",   "mapping": [ {       "address": 80,       "bus_datatype": 4,       "type": "register",       "name": "operating hours"          }, ] }
Modbus profile of LM internally supports ONLY uint16 registers without type switchin - by Streety - 19.12.2025, 16:49
