problems with scripts
You basically must create additional object where you will write the final result of your logic. You have 3 inputs values, door, occupancy and presence detection. TAG all 3 objects and then your event script trigger should this tag. Select it after editing event script settings and in Group address / tag: you will find it on the bottom. Create 4th object to which you will write result of your logic. DO not add TAG to it otherwise you will have another loop.
problems with scripts - by ALEJANDRO - 07.01.2026, 13:21
RE: problems with scripts - by Daniel - 07.01.2026, 14:15
RE: problems with scripts - by ALEJANDRO - 07.01.2026, 14:40
RE: problems with scripts - by Daniel - 07.01.2026, 14:50
RE: problems with scripts - by ALEJANDRO - 07.01.2026, 15:32
RE: problems with scripts - by ALEJANDRO - 09.01.2026, 12:02
RE: problems with scripts - by ALEJANDRO - 12.01.2026, 10:52
RE: problems with scripts - by Daniel - 12.01.2026, 10:59
RE: problems with scripts - by ALEJANDRO - 12.01.2026, 12:13
RE: problems with scripts - by Daniel - 12.01.2026, 12:44
