Visu bugs
#76
(30.01.2026, 10:19)admin Wrote: Can you post a screenshot? Value select in icon mode uses horizontal layout by default. Unless column count is set of course.
Column count is and was not set - I hadn't discovered that setting yet. This is how it looks:
and this is how I want it to look:
(I can work around this by not using custom widgets on this particular page, but there are other uses where I want it - even in tile view...)
I see that the same is valid for the spinner (and probably all other widgets) - that they just show up inside the containment of the custom widget. But those are usually smaller than the custom widget, so it's not necessarily a problem... Hmmhmm.
And since I have your attention, I have a feature request for custom widgets - would it be possible to include "Text label" in the "Replace group address"-tab of custom widgets..? (Or another separate way of replacing them)
Visu bugs - by Daniel - 19.02.2025, 13:08
RE: Visu bugs - by balatis - 10.03.2025, 13:26
RE: Visu bugs - by Omega Technology - 01.04.2025, 18:02
RE: Visu bugs - by AEK - 01.04.2025, 19:53
RE: Visu bugs - by Omega Technology - 02.04.2025, 19:23
RE: Visu bugs - by Daniel - 02.04.2025, 19:30
RE: Visu bugs - by stianj - 14.04.2025, 22:22
RE: Visu bugs - by admin - 15.04.2025, 12:58
RE: Visu bugs - by Novodk - 20.05.2025, 21:11
RE: Visu bugs - by Daniel - 21.05.2025, 07:06
RE: Visu bugs - by Novodk - 21.05.2025, 07:20
RE: Visu bugs - by Chandrias - 25.05.2025, 15:05
RE: Visu bugs - by admin - 26.05.2025, 06:13
RE: Visu bugs - by Chandrias - 23.06.2025, 15:26
RE: Visu bugs - by Daniel - 23.06.2025, 15:28
RE: Visu bugs - by Novodk - 01.10.2025, 07:55
RE: Visu bugs - by Daniel - 01.10.2025, 07:59
RE: Visu bugs - by Novodk - 02.10.2025, 06:15
RE: Visu bugs - by admin - 02.10.2025, 06:35
RE: Visu bugs - by Novodk - 06.10.2025, 06:24
RE: Visu bugs - by Chandrias - 23.10.2025, 20:17
RE: Visu bugs - by Daniel - 24.10.2025, 07:22
RE: Visu bugs - by Chandrias - 28.10.2025, 16:15
RE: Visu bugs - by Daniel - 28.10.2025, 16:16
RE: Visu bugs - by Chandrias - 28.10.2025, 16:20
RE: Visu bugs - by Daniel - 29.10.2025, 08:04
RE: Visu bugs - by Chandrias - 31.10.2025, 17:46
RE: Visu bugs - by cekca - 29.10.2025, 10:49
RE: Visu bugs - by Daniel - 29.10.2025, 10:54
RE: Visu bugs - by cekca - 29.10.2025, 11:06
RE: Visu bugs - by Daniel - 29.10.2025, 11:17
RE: Visu bugs - by Juande - 30.10.2025, 18:29
RE: Visu bugs - by Daniel - 31.10.2025, 09:14
RE: Visu bugs - by Juande - 31.10.2025, 16:21
RE: Visu bugs - by admin - 03.11.2025, 12:57
RE: Visu bugs - by stianj - 05.11.2025, 10:23
RE: Visu bugs - by stianj - 30.01.2026, 09:59
RE: Visu bugs - by Daniel - 05.11.2025, 13:59
RE: Visu bugs - by stianj - 05.11.2025, 14:23
RE: Visu bugs - by Daniel - 05.11.2025, 14:30
RE: Visu bugs - by stianj - 06.11.2025, 08:40
RE: Visu bugs - by CristianAgata - 09.11.2025, 08:34
RE: Visu bugs - by Daniel - 10.11.2025, 08:28
RE: Visu bugs - by Daniel - 10.11.2025, 17:07
RE: Visu bugs - by CristianAgata - 10.11.2025, 17:10
RE: Visu bugs - by AlexLV - 11.11.2025, 10:47
RE: Visu bugs - by Daniel - 11.11.2025, 10:49
RE: Visu bugs - by AlexLV - 11.11.2025, 13:30
RE: Visu bugs - by Daniel - 12.11.2025, 14:16
RE: Visu bugs - by davidchispas - 20.11.2025, 13:27
RE: Visu bugs - by Daniel - 21.11.2025, 13:40
RE: Visu bugs - by gdimaria - 14.01.2026, 07:56
RE: Visu bugs - by Daniel - 14.01.2026, 08:32
RE: Visu bugs - by gdimaria - 14.01.2026, 15:16
RE: Visu bugs - by Novodk - 16.01.2026, 16:56
RE: Visu bugs - by Daniel - 16.01.2026, 17:01
RE: Visu bugs - by Novodk - 16.01.2026, 17:12
RE: Visu bugs - by Fahd - 19.01.2026, 08:11
RE: Visu bugs - by Daniel - 19.01.2026, 08:35
RE: Visu bugs - by Fahd - 20.01.2026, 18:56
RE: Visu bugs - by admin - 21.01.2026, 07:56
RE: Visu bugs - by Fahd - 21.01.2026, 16:16
RE: Visu bugs - by Daniel - 21.01.2026, 16:17
RE: Visu bugs - by Daniel - 22.01.2026, 08:52
RE: Visu bugs - by admin - 22.01.2026, 09:13
Visu input text and number bugs - by devitec - 23.01.2026, 11:15
RE: Visu bugs - by Daniel - 23.01.2026, 13:09
RE: Visu bugs - by Daniel - 23.01.2026, 13:52
RE: Visu bugs - by Chandrias - 26.01.2026, 10:36
RE: Visu bugs - by Daniel - 26.01.2026, 10:37
RE: Visu bugs - by Chandrias - 26.01.2026, 10:59
RE: Visu bugs - by Daniel - 30.01.2026, 10:02
RE: Visu bugs - by stianj - 30.01.2026, 10:14
RE: Visu bugs - by admin - 30.01.2026, 10:19
RE: Visu bugs - by stianj - 30.01.2026, 12:01
RE: Visu bugs - by Daniel - 30.01.2026, 10:21
RE: Visu bugs - by admin - 30.01.2026, 13:29
RE: Visu bugs - by stianj - 30.01.2026, 13:49
RE: Visu bugs - by Juande - 30.01.2026, 19:06
RE: Visu bugs - by Daniel - 02.02.2026, 08:25
RE: Visu bugs - by Juande - 02.02.2026, 11:23
RE: Visu bugs - by admin - 02.02.2026, 11:45
RE: Visu bugs - by Juande - 02.02.2026, 12:59
RE: Visu bugs - by admin - 06.02.2026, 12:58
RE: Visu bugs - by CarlS - 10.02.2026, 17:32
RE: Visu bugs - by davidchispas - 22.03.2026, 21:39
RE: Visu bugs - by Daniel - 23.03.2026, 08:04
RE: Visu bugs - by admin - 23.03.2026, 13:46
RE: Visu bugs - by davidchispas - 25.03.2026, 12:08
RE: Visu bugs - by KoBra - 27.03.2026, 10:14
RE: Visu bugs - by admin - 27.03.2026, 10:14
RE: Visu bugs - by KoBra - 27.03.2026, 14:50
RE: Visu bugs - by Daniel - 27.03.2026, 14:53
RE: Visu bugs - by KoBra - 27.03.2026, 17:50
RE: Visu bugs - by Novodk - 09.04.2026, 10:19
RE: Visu bugs - by Daniel - 09.04.2026, 10:23
RE: Visu bugs - by Novodk - 09.04.2026, 10:29
RE: Visu bugs - by KoBra - 31.05.2026, 12:51
RE: Visu bugs - by admin - 01.06.2026, 06:09
RE: Visu bugs - by KoBra - 03.06.2026, 09:55
RE: Visu bugs - by KoBra - 02.06.2026, 22:11
RE: Visu bugs - by Daniel - 03.06.2026, 10:09
RE: Visu bugs - by Daniel - 03.06.2026, 07:25
RE: Visu bugs - by stianj - 03.06.2026, 09:35
RE: Visu bugs - by KoBra - 03.06.2026, 10:10
RE: Visu bugs - by Daniel - 03.06.2026, 09:38
RE: Visu bugs - by stianj - 03.06.2026, 11:01
RE: Visu bugs - by gtsamis - 03.06.2026, 16:40
RE: Visu bugs - by admin - 04.06.2026, 13:21
RE: Visu bugs - Thermostat - by cranz - 05.08.2026, 08:24
RE: Visu bugs - by Daniel - 05.08.2026, 08:38
RE: Visu bugs - by cranz - 05.08.2026, 08:53
RE: Visu bugs - by Daniel - 05.08.2026, 09:01
RE: Visu bugs - by AlexLV - 30.09.2026, 11:52
RE: Visu bugs - by lucacs04 - 09.10.2026, 15:09
RE: Visu bugs - by Daniel - 09.10.2026, 15:12
RE: Visu bugs - by lucacs04 - 09.10.2026, 15:19
RE: Visu bugs - by Daniel - 09.10.2026, 16:15
RE: Visu bugs - by lucacs04 - 12.10.2026, 07:20
RE: Visu bugs - by admin - 12.10.2026, 07:29
RE: Visu bugs - by Daniel - 12.10.2026, 07:41
