16.02.2026, 11:20
(This post was last modified: 16.02.2026, 11:20 by PedroPinto.)
Hello i finally have 2 ip routers, one on line 1.1, the other on line 1.2, LM its set up at KNX connect mode as IP routing.
Now i guess what i'll ask now its not something related to LM but about ETS.
If i have both ip routers with Routing (IP-KNX) group telegrams set up as "Route", from the LM i can write into the group addresses. These group addresses only have objects from the devices of the same line. If i set up the group telegrams as "Filter" (to avoid KNX telegrams crossing one line to another), it just doesn't work, LM doesnt read (i guess the IP routers are blocking). I have ETS 6.3.0 and i can't manual edit the filter tables of the IP Routers, they are just blank, the only way i can see something on the filter table is if i have a group address with a group object from a device of line 1 and a group object from a device of line 2, that group address gets automatically added to the filter table of both ip routers and then LM can read the state.
