Siemens PXC controller and LM bacnet client for Visu
Hi there,
I am looking for a tool to visualize Siemens PXC4/5/7 controllers with LM communicating the data points via Bacnet/IP.
If I understand correctly in this case I would need to use the bacnet client library of LM.  I tried looking into the capabilities of the bacnet client and I have found older forum posts stating that it's limited in the number of data points it can handle and also lacks discovery features.
Would there be a viable solution to read and write a few hundreds of data points with the bacnet client of LM? If not, could you recommend any other solutions with LM?
Thank you for your answer in anticipation!
Siemens PXC controller and LM bacnet client for Visu - by MuranyiD - 24.02.2026, 12:47
