communication vbus solar resol
#43
I finally got it working thanks to AI. For everybody struggeling. Please find my working script below.
local http = require('socket.http') local bit = require('bit') -- CONFIGURATION local url = 'http://192.168.1.1/current/current_packets.vbus' local alarm_obj = '0/4/28' -- DPT 1.005: 1 = ALARM, 0 = OK function parseVBus()   local response, status = http.request(url)     -- 1. HTTP Connection Check (Network/KM2 Failure)   if status ~= 200 or not response then     grp.checkupdate(alarm_obj, true) -- ALARM ON     log("[SLL ALARM] KM2 unreachable. Network or Power issue.")     return   end   local function getVal(b1, b2)     if not b1 or not b2 then return 0 end     local v = (b2 * 256) + b1     if v > 32767 then v = v - 65536 end     return v * 0.1   end   -- 2. Find the primary SLL Data Header   local p = response:find('\16\00\113\34\16')     if p then     -- System is healthy     grp.checkupdate(alarm_obj, false) -- ALARM OFF (OK)     -- SENSORS     local s1 = getVal(response:byte(p+16), response:byte(p+17))     local s2 = getVal(response:byte(p+18), response:byte(p+19))     local s3 = getVal(response:byte(p+20), response:byte(p+21))         local s4 = 0     local p_extra = response:find('\16\00\00\01\76', p)     if p_extra then        s4 = getVal(response:byte(p_extra+18), response:byte(p_extra+19))     end     -- PWM & RELAYS (Verified Mapping)     local pwa = response:byte(p+32) or 0 -- PWM A     local r2  = response:byte(p+33) or 0 -- Relay 2 (Diverting Valve)     local mask = response:byte(p+40) or 0     local r1  = (bit.band(mask, 0x01) == 0x01) and 100 or 0 -- Relay 1 (Pump Power)     -- Safety Cleanup     if pwa > 100 then pwa = 0 end     if r1 > 100 then r1 = 100 end     if r2 > 100 then r2 = 100 end     -- KNX UPDATES     grp.checkupdate('0/4/26', s1)     grp.checkupdate('0/4/20', s2)     grp.checkupdate('0/4/23', s3)     grp.checkupdate('0/4/21', s4)     grp.checkupdate('0/4/24', pwa)     grp.checkupdate('0/4/27', r1)     grp.checkupdate('0/4/25', r2)   else     -- 3. Data Header Missing (VBus Cable or Controller Mode Failure)     grp.checkupdate(alarm_obj, true) -- ALARM ON     log("[SLL ALARM] KM2 online but VBus data stream invalid.")   end end parseVBus()
communication vbus solar resol - by 69jtdti - 15.07.2016, 16:13
RE: communication vbus solar resol - by lpala - 12.11.2016, 15:45
RE: communication vbus solar resol - by lpala - 01.12.2016, 09:36
RE: communication vbus solar resol - by lpala - 18.01.2017, 21:32
RE: communication vbus solar resol - by lpala - 22.01.2017, 17:20
RE: communication vbus solar resol - by admin - 23.01.2017, 08:49
RE: communication vbus solar resol - by lpala - 23.01.2017, 21:21
RE: communication vbus solar resol - by lpala - 22.02.2017, 08:37
RE: communication vbus solar resol - by lpala - 23.04.2017, 21:28
RE: communication vbus solar resol - by lpala - 29.04.2017, 07:19
RE: communication vbus solar resol - by admin - 13.11.2017, 06:57
RE: communication vbus solar resol - by lpala - 23.12.2017, 18:05
RE: communication vbus solar resol - by admin - 13.11.2017, 11:11
RE: communication vbus solar resol - by KoBra - 09.03.2021, 11:33
RE: communication vbus solar resol - by KoBra - 16.03.2021, 11:26
RE: communication vbus solar resol - by admin - 16.03.2021, 11:30
RE: communication vbus solar resol - by KoBra - 02.01.2023, 16:32
RE: communication vbus solar resol - by admin - 03.01.2023, 09:36
RE: communication vbus solar resol - by KoBra - 03.01.2023, 11:16
RE: communication vbus solar resol - by KoBra - 04.01.2023, 20:04
RE: communication vbus solar resol - by admin - 05.01.2023, 08:19
RE: communication vbus solar resol - by KoBra - 06.01.2023, 14:15
RE: communication vbus solar resol - by admin - 06.01.2023, 14:16
RE: communication vbus solar resol - by KoBra - 06.01.2023, 21:29
RE: communication vbus solar resol - by KoBra - 07.01.2023, 22:29
RE: communication vbus solar resol - by KoBra - 08.01.2023, 19:39
RE: communication vbus solar resol - by admin - 09.01.2023, 07:59
RE: communication vbus solar resol - by KoBra - 09.01.2023, 08:33
RE: communication vbus solar resol - by admin - 09.01.2023, 08:41
RE: communication vbus solar resol - by KoBra - 09.01.2023, 08:57
RE: communication vbus solar resol - by admin - 09.01.2023, 09:29
RE: communication vbus solar resol - by KoBra - 09.01.2023, 10:45
RE: communication vbus solar resol - by KoBra - 24.01.2023, 09:31
RE: communication vbus solar resol - by admin - 24.01.2023, 10:11
RE: communication vbus solar resol - by KoBra - 28.02.2026, 17:08
