31.03.2026, 10:27
BACnet:
Make sure that each LM has a unique Device ID (System config > Network > BACnet settings).
KNX/IP filtering:
Make sure that each LM has a unique KNX address (System config > Network > KNX connection).
On LM2 and LM3 set "IP > Local" SRC policy to "Drop" and put LM1 address into the "Ind. address list". You can also block LM2 from LM3 and LM3 from LM2 the same way if needed.
KNX/IP filtering:
