ping on VLAN and outside
(24.04.2026, 06:39)admin Wrote: What is the LM local IP address? The route that you have posted does not look right. Router address should be an IP address that belongs to the same subnet as LM, but the destination network must be something different.
Alternatively you can add another local IP address:
os.execute('ifconfig eth0:1 192.168.2.2 netmask 255.255.255.0 up')
Good morning, Daniel
I attach file for current net setting from naetwork staff.
I've now disabled LTE and zero-tier. The device works fine on the VPN and as a programming port. I can send SMS messages, but not emails. Could it be that the emails trying to go out are using the network with the parameters set and the network isn't enabled to send emails?
Now I'll try contacting the network technicians and see how I can resolve the issue. Otherwise, can you offer alternative solutions?
As always, thank you very much.
ping on VLAN and outside - by Frank68 - 21.04.2026, 09:44
RE: ping on VLAN and outside - by admin - 21.04.2026, 11:03
RE: ping on VLAN and outside - by Frank68 - 21.04.2026, 11:30
RE: ping on VLAN and outside - by admin - 21.04.2026, 11:34
RE: ping on VLAN and outside - by Frank68 - 21.04.2026, 12:12
RE: ping on VLAN and outside - by Frank68 - 23.04.2026, 14:52
RE: ping on VLAN and outside - by admin - 21.04.2026, 12:22
RE: ping on VLAN and outside - by Frank68 - 21.04.2026, 12:28
RE: ping on VLAN and outside - by admin - 21.04.2026, 12:29
RE: ping on VLAN and outside - by Frank68 - 21.04.2026, 12:36
RE: ping on VLAN and outside - by Daniel - 21.04.2026, 12:51
RE: ping on VLAN and outside - by Frank68 - 21.04.2026, 12:55
RE: ping on VLAN and outside - by admin - 21.04.2026, 12:57
RE: ping on VLAN and outside - by Frank68 - 21.04.2026, 13:01
RE: ping on VLAN and outside - by Daniel - 21.04.2026, 13:10
RE: ping on VLAN and outside - by Frank68 - 21.04.2026, 13:17
RE: ping on VLAN and outside - by Daniel - 21.04.2026, 13:22
RE: ping on VLAN and outside - by admin - 24.04.2026, 06:39
RE: ping on VLAN and outside - by Frank68 - 24.04.2026, 08:13
RE: ping on VLAN and outside - by admin - 24.04.2026, 08:41
RE: ping on VLAN and outside - by Frank68 - 24.04.2026, 13:00
RE: ping on VLAN and outside - by admin - 24.04.2026, 13:02
