block addresses within the logic machine itself
You should use Virtual objects instead.
A work around is to make sure to not select: wirte to bus in the mapping page.
This will block only writing to TP. To block writing to IP you must use KNX filter table and block these groups in the filter (Local to IP)
RE: block addresses within the logic machine itself - by Daniel - 14.05.2026, 14:50
