Usernames in log
You can prepare .lp file with such script:
<? now=os.microtime() last_login = db:getall('SELECT * FROM user_logs ORDER BY created DESC LIMIT 1') user = last_login[1].login print(user) ?>
and you can use it from js.
As in this thread:
http://forum.logicmachine.net/showthread...le#pid3118
Unfortunately there is at least 1 possible problem when 2 users login in the same time(if more than 1 second it should be ok).
Maybe this is not a perfect solution but at this moment can be helpful. You can also improve it.
A minute ago I've found some solution from Erwin and now it is possible to recognize very precisely who is who.
So .lp file should looks like here:
<? require('genohm-scada') require('dbenv') db = dbenv:new() ip = ngx.var.remote_addr user = db:getall("SELECT login FROM user_logs WHERE ip='" .. ip .. "' ORDER BY created DESC LIMIT 1") print(user[1].login) ?>
Usernames in log - by Thomas - 07.03.2017, 12:14
RE: Usernames in log - by admin - 07.03.2017, 12:53
RE: Usernames in log - by buuuudzik - 07.03.2017, 13:26
RE: Usernames in log - by cekca - 20.04.2017, 12:06
RE: Usernames in log - by Thomas - 08.03.2017, 19:18
RE: Usernames in log - by buuuudzik - 20.04.2017, 15:20
RE: Usernames in log - by admin - 20.04.2017, 15:37
RE: Usernames in log - by buuuudzik - 20.04.2017, 16:16
