Frame Trend logs from Neighbour
This can work but it is not related to Visu only how the modern browsers works. First you must use HTTPS on both controllers and in the frame url. Second you must create valid SSL certificate for both LMs(use SSL cert app) Last point is to set Remember password in User settings. It will ask you for credentials once till the remember parameter will expire.
Frame Trend logs from Neighbour - by function - 09.07.2026, 15:59
RE: Frame Trend logs from Neighbour - by Daniel - 09.07.2026, 16:09
