Required MQTT resources
What the alarm scripts are going to do? Use tags for event scripts so you don't have to make many multiple copies of the same script.
If all LMs are on the same network then you can use KNX/IP instead of MQTT. Just make sure to setup filtering correctly.
Required MQTT resources - by Frank68 - 23.09.2026, 06:51
RE: Required MQTT resources - by admin - 23.09.2026, 06:53
RE: Required MQTT resources - by Daniel - 23.09.2026, 07:02
