Direct input / Step + / -
Hello
I have an issue with the "Direct input / Step + / -"
I use this fore a Base-setpoint for temperature, and added Minimum value (18) and Maximum value (25)
When a user wants to max out his setpoint (they always click maximum..) the Step + will exceed its limit (25) eg stepping up to 25.5
The Visualisation will stop on 25, but the telegram will not be sent. It exceeds max of 25, and block the group.write on BUS
on the Visualiasation-page it shows max (25) but no changes are made.
If you visualize this value other pages, it will remain on the start before the multiple step-clicks
Could we somehow send the max-value when user Click 1-1000 times to many??
The way it is now no changes are made, and users are confused.
One suggestion I have is to allow all values, and do the limit in Script.
Simplified like this:
When Value is > 25 write 25 (if they click to + 34) Script will write 25....
I would do that on all 400 tags...
Not ideal, but could work..
Any better suggestions?
Darth Paul
Direct input / Step + / - - by DarthPaul - 04.05.2017, 09:23
RE: Direct input / Step + / - - by admin - 04.05.2017, 09:52
RE: Direct input / Step + / - - by DarthPaul - 10.05.2017, 09:55
RE: Direct input / Step + / - - by admin - 10.05.2017, 10:42
RE: Direct input / Step + / - - by DarthPaul - 15.05.2017, 19:29
