09.06.2017, 16:44
In case of reactor's the second power supply is only needed where one supply is not enough for 24V outputs. It does not provide output separation. You can try connecting valves directly to 24V outputs since they draw less than the allowed maximum. If this does not work, then you can always install an additional relay. Most DIN-rail relays already have a diode inside for reverse current protection.
