09.06.2017, 19:54
Thanks for answering!
The valves are available in an other wiring version BD3 (see attached image) that only needs one switch (SPST) but it uses a little more current. If I am to use the LogicMachines I/O with the B3 wiring how would I wire it up? Can LogicMachines output work as NO, NC and COM? Or would I wire it as I had two separate relays?
Would it make more sense to get the BD3 that only requires one switch?
Are there any advantage with a B3 wiring version(one would think so since it is more complicated)?
Joachim
Joachim
