14.06.2017, 07:50
(13.06.2017, 19:41)AlexLV Wrote: Mikrotik network devices more and more popular. I used it more than 2 years.. Know that Mikrotk has API. Can we integrate it with LM?
Possible use - try to swith WiFi On/Off by deep night over LAN from LM, if Mobile device registered at home Wifi - you can start scripts on LM, - Home automatics works you are just comming closer to home... :If somebody try to connect to home Wifi - Mikrotik and LM can try to inform you... API works with no problem with .php, but I don't know LM possibilities..
Have link to some info (russian) :
http://asp24.com.ua/blog/mikrotik-router...i-connect/
https://tugibaev.ru/2014/04/dhcp-lease-m...otify-sms/
Hi, AlexLV!
It's time to start russian threads on forum
you could try to send http request from microtic to LM and then do some logic operations on microtic.
I found some links that might help you (Russian too)
https://toster.ru/q/196163
https://wiki.mikrotik.com/wiki/Manual:Tools/Fetch
in LM you should use remote services
http://openrb.com/docs/remote-new.htm - for 2016 FW and newer
http://openrb.com/docs/remote.htm - for pre 2016 FW
