F&F LE-03MQ Modbus energy counter
#35
1) I've tried also with switching on Modbus mapper, and after this, reading all of this registers takes only 4 seconds so I see that other RS-485 inputs are connected with themselves.
2) When I switched on the Modbus mapper then still reading the registers via script takes 3-5 seconds. It is enough, but if there would be a possibility to go down to 1 second it would be great from the learning pointWink What I can improve in below script? (When I am changing timeout the interval is still the same)
start = os.microtime() require('json') require('luamodbus') mb = luamodbus.rtu() mb:open('/dev/RS485-2', 9600, 'N', 8, 1, 'H') mb:connect() timeout = 0.020 mb:setresponsetimeout(timeout) mb:setslave(4) energyMeters = [[ {  "manufacturer": "F&F",  "description": "Licznik energii LE-03MQ",  "mapping": [     { "address": 0, "name": "Napięcie fazowe L1", "delta": 2 },     { "address": 2, "name": "Napięcie fazowe L2", "delta": 2 },     { "address": 4, "name": "Napięcie fazowe L3", "delta": 2 },     { "address": 6, "name": "Natężenie prądu L1", "delta": 0.5 },     { "address": 8, "name": "Natężenie prądu L2", "delta": 0.5 },     { "address": 10, "name": "Natężenie prądu L3", "delta": 0.5 },     { "address": 12, "name": "Moc czynna L1", "delta": 50 },     { "address": 14, "name": "Moc czynna L2", "delta": 50 },     { "address": 16, "name": "Moc czynna L3", "delta": 20 },     { "address": 24, "name": "Moc bierna L1", "delta": 50 },     { "address": 26, "name": "Moc bierna L2", "delta": 50 },     { "address": 28, "name": "Moc bierna L3", "delta": 50 },     { "address": 30, "name": "Współczynnik mocy L1", "delta": 0.01 },     { "address": 32, "name": "Współczynnik mocy L2", "delta": 0.01 },     { "address": 34, "name": "Współczynnik mocy L3", "delta": 0.01 },     { "address": 52, "name": "Całkowita moc układu", "delta": 50 },     { "address": 60, "name": "Całkowita moc bierna układu", "delta": 50 },     { "address": 62, "name": "Współczynnik mocy układu", "delta": 0.01 },     { "address": 70, "name": "Częstotliwość napięć zasilania", "delta": 0.25 },     { "address": 200, "name": "Napięcie międzyfazowe L1-L2", "delta": 2 },     { "address": 202, "name": "Napięcie międzyfazowe L2-L3", "delta": 2 },     { "address": 204, "name": "Napięcie międzyfazowe L3-L1", "delta": 2 },     { "address": 224, "name": "Prąd przewodu zerowego", "delta": 1 },     { "address": 234, "name": "Współczynnik zawartości harmonicznych napięcia L1-N", "delta": 1 },     { "address": 236, "name": "Współczynnik zawartości harmonicznych napięcia L2-N", "delta": 1 },     { "address": 238, "name": "Współczynnik zawartości harmonicznych napięcia L3-N", "delta": 1 },     { "address": 240, "name": "Harmoniczne prądu fazy 1", "delta": 1 },     { "address": 242, "name": "Harmoniczne prądu fazy 2", "delta": 1 },     { "address": 244, "name": "Harmoniczne prądu fazy 3", "delta": 1 },     { "address": 334, "name": "Harmoniczna napięcia międzyfazowego L1-L2", "delta": 1 },     { "address": 336, "name": "Harmoniczna napięcia międzyfazowego L2-L3", "delta": 1 },     { "address": 338, "name": "Harmoniczna napięcia międzyfazowego L3-L1", "delta": 1 },     { "address": 342, "name": "Całkowita energia czynna", "delta": 0.1 },     { "address": 344, "name": "Całkowita energia bierna", "delta": 0.1 }      ] }]] errors = 0 energyMeters = json.decode(energyMeters) meterName = 'Licznik 1 - ' function readRegister(meterName, address, name, delta)  for i = 1, 7, 1 do    res, err = mb:readinputregistervalue(address, "float32", "w")    if res then        GA = meterName .. name          value = math.round(res, 2)      grp.checkwrite(GA, value, delta)      break    else      errors = errors + 1    end  end end for k,meter in pairs(energyMeters.mapping) do  readRegister(meterName, meter.address, meter.name, meter.delta) end mb:close() developmentInfo = false if developmentInfo then log('Duration: ' .. os.microtime()-start .. 's, ' .. errors .. 'errors') end
If it is about LM Load Balancer please provide some example how can I mount RS-485<>USB converter ch340.
http://blog.lincomatic.com/?p=1616
RE: F&F LE-03MQ Modbus energy counter - by buuuudzik - 27.09.2017, 13:53
