Zwave - Fibaro Motion Sensor
#29
Hello
I managed to integrate zwave, rf devices, .... by using domoticz as gateway, for now I only use it for switching zwave and rf devices and it works pretty well
domoticz you find here (I installed it on a synology nas):
https://www.domoticz.com/
below my user library
DOMOTICZ_IP = '192.168.0.12' DOMOTICZ_PORT = '8084' DOMOTICZ_ID_BASEMENT_COMPRESSOR = '23' DOMOTICZ_ID_LIVINGROOM_READING_LIGHT = '215' DOMOTICZ_ID_LIVINGROOM_VENTILATOR = '102' KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF = '8/0/0' KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF_STATUS = '8/0/1' KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF = '8/1/0' KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF_STATUS = '8/1/1' KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF = '8/1/2' KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF_STATUS = '8/1/3' -- write value to knx only if value changed function writeKNX(group, value, default, typ)  local key,time   --  time = os.microtime() --  log('writeKNX(group, value, typ)',group,value,typ)  key = 'KNX_GRP_' .. string.gsub(group, "/", "_") --  log('writeKNX(group, value, typ)',key)  if ((storage.get(key, default)) ~= value) then --    log('now writing writeKNX(group, value, typ)',key, group, value)    storage.set(key, value)    grp.write(group, value, typ)  end end -- toggle on / off function domoticzSwitch(host, port, domoticzId, value)  local time --  time = os.microtime() --  log('domoticzSwitch(host, port, domoticzId, value)',host, port, domoticzId, value)  if (value == true) then    domoticzCmd(host, port, domoticzId, 'switchlight', 'On')  else    domoticzCmd(host, port, domoticzId, 'switchlight', 'Off')  end   --  time = os.microtime() - time --  log('domoticzSwitch(host, port)',host, port, domoticzId, value, time) end -- get On Off Status function domoticzGetSwitchStatus(host, port, domoticzId)  local time, status --  time = os.microtime() --  log('domoticzGetSwitchStatus(host, port, domoticzId)',host, port, domoticzId)  status = domoticzStatus(host,port,domoticzId)  result =  (status.result[1].Status == "On")   --  time = os.microtime() - time --  log('domoticzGetSwitchStatus(host, port, domoticzId)',host, port, domoticzId, result, time)  return result end -- send command to domoticz function domoticzCmd(host, port, domoticzId, domoticzCmd, cmdParam)  local http, request,r, c, h --  time = os.microtime() --  log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam)     -- load the http module     local http = require("socket.http")  request = "http://" .. host .. ":" .. port .. "/json.htm?type=command&param=" .. domoticzCmd .. "&idx=" .. domoticzId .. "&switchcmd=" .. cmdParam --  log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam, request)     -- connect to server  r, c, h = http.request (request) --  time = os.microtime() - time --  log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam, r, c, h, time) end -- retrieve a status from domoticz function domoticzStatus(host, port, domoticzId)  local http, request,r, c, h --  time = os.microtime() --  log('domoticzStatus', host, port, domoticzId)  -- build the http request     local http = require("socket.http")  request = "http://" .. host .. ":" .. port .. "/json.htm?type=devices&rid=" .. domoticzId-- --  log('domoticzStatus', host, port, domoticzId, request)  -- execute the http request  r, c, h = http.request (request) --  time = os.microtime() - time --  log('domoticzStatus', host, port, domoticzId, r, c, h, time)  -- decode the json object  local json = require("json")    local statusobject = json.pdecode(r)  return statusobject end
here a trigger to switch a device based a knx event
SCRIPT = 'user.library' lib = require(SCRIPT) if not lib then alert('Event ' .. event .. ' not handled: script ' .. SCRIPT .. ' missing') os.sleep(60) return end -- object mapped to this event must have its data type set value = event.getvalue() -- toggle on/off domoticzSwitch(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_VENTILATOR, value) -- only write on changed data writeKNX(KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF_STATUS, value, false, dt.bool)
finally my deamon script to ensure that the knx status is correctly set even if I use domoticz or my zwave remote
SCRIPT = 'user.library' lib = require(SCRIPT) if not lib then alert('Event ' .. event .. ' not handled: script ' .. SCRIPT .. ' missing') os.sleep(60) return end ----------------------------------- -- determine the domticz status ----------------------------------- -- basement bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_BASEMENT_COMPRESSOR) writeKNX(KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF, bStatus, false, dt.bool) -- livingroom -- reading light bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_READING_LIGHT) -- only write on changed data --writeKNX(KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF, bStatus, false, dt.bool) -- ventilator bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_VENTILATOR) -- only write on changed data --writeKNX(KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF, value, false, dt.bool)
I am sure code could be cleaner but I am still learning lua
Enjoy Smile
Next step let a mobotix cam trigger the opening/closing of doors, but manage the opening hours per user through logic machine
RE: Zwave - Fibaro Motion Sensor - by edgars - 01.07.2015, 08:57
RE: Zwave - Fibaro Motion Sensor - by edgars - 02.07.2015, 08:07
RE: Zwave - Fibaro Motion Sensor - by edgars - 03.07.2015, 12:03
RE: Zwave - Fibaro Motion Sensor - by Peter - 09.07.2015, 07:30
RE: Zwave - Fibaro Motion Sensor - by edgars - 27.08.2015, 09:53
RE: Zwave - Fibaro Motion Sensor - by andeug - 18.09.2015, 16:15
RE: Zwave - Fibaro Motion Sensor - by admin - 21.09.2015, 08:45
RE: Zwave - Fibaro Motion Sensor - by andeug - 27.09.2015, 09:18
RE: Zwave - Fibaro Motion Sensor - by admin - 28.09.2015, 06:18
RE: Zwave - Fibaro Motion Sensor - by andeug - 29.09.2015, 19:33
RE: Zwave - Fibaro Motion Sensor - by edgars - 30.09.2015, 06:28
RE: Zwave - Fibaro Motion Sensor - by edgars - 08.10.2015, 12:48
RE: Zwave - Fibaro Motion Sensor - by admin - 11.11.2015, 07:07
RE: Zwave - Fibaro Motion Sensor - by admin - 12.11.2015, 07:45
RE: Zwave - Fibaro Motion Sensor - by npinguin - 25.11.2015, 22:01
RE: Zwave - Fibaro Motion Sensor - by admin - 26.11.2015, 07:02
RE: Zwave - Fibaro Motion Sensor - by edgars - 19.01.2016, 09:00
RE: Zwave - Fibaro Motion Sensor - by edgars - 19.01.2016, 10:38
RE: Zwave - Fibaro Motion Sensor - by edgars - 29.01.2016, 11:49
RE: Zwave - Fibaro Motion Sensor - by edgars - 29.01.2016, 12:19
RE: Zwave - Fibaro Motion Sensor - by edgars - 03.03.2016, 09:42
RE: Zwave - Fibaro Motion Sensor - by edgars - 04.04.2016, 13:03
RE: Zwave - Fibaro Motion Sensor - by edgars - 05.04.2016, 07:05
RE: Zwave - Fibaro Motion Sensor - by edgars - 07.04.2016, 07:49
RE: Zwave - Fibaro Motion Sensor - by edgars - 12.04.2016, 11:47
RE: Zwave - Fibaro Motion Sensor - by edgars - 28.04.2016, 09:00
RE: Zwave - Fibaro Motion Sensor - by edgars - 04.08.2016, 09:57
RE: Zwave - Fibaro Motion Sensor - by andeug - 07.08.2016, 13:54
RE: Zwave - Fibaro Motion Sensor - by admin - 17.08.2016, 06:36
RE: Zwave - Fibaro Motion Sensor - by gaxy - 17.08.2016, 08:53
RE: Zwave - Fibaro Motion Sensor - by admin - 17.08.2016, 09:08
RE: Zwave - Fibaro Motion Sensor - by baggins - 22.02.2017, 21:48
RE: Zwave - Fibaro Motion Sensor - by baggins - 23.02.2017, 16:47
RE: Zwave - Fibaro Motion Sensor - by baggins - 23.02.2017, 22:48
RE: Zwave - Fibaro Motion Sensor - by baggins - 24.02.2017, 07:39
RE: Zwave - Fibaro Motion Sensor - by admin - 24.02.2017, 09:58
RE: Zwave - Fibaro Motion Sensor - by baggins - 24.02.2017, 10:07
RE: Zwave - Fibaro Motion Sensor - by baggins - 28.03.2017, 11:21
RE: Zwave - Fibaro Motion Sensor - by edgars - 28.03.2017, 12:34
RE: Zwave - Fibaro Motion Sensor - by baggins - 28.03.2017, 12:59
RE: Zwave - Fibaro Motion Sensor - by baggins - 29.03.2017, 13:06
RE: Zwave - Fibaro Motion Sensor - by edgars - 30.03.2017, 12:56
RE: Zwave - Fibaro Motion Sensor - by baggins - 30.03.2017, 17:03
RE: Zwave - Fibaro Motion Sensor - by baggins - 31.03.2017, 17:09
RE: Zwave - Fibaro Motion Sensor - by edgars - 03.04.2017, 06:41
RE: Zwave - Fibaro Motion Sensor - by baggins - 18.05.2017, 15:59
RE: Zwave - Fibaro Motion Sensor - by admin - 18.05.2017, 16:23
RE: Zwave - Fibaro Motion Sensor - by baggins - 18.05.2017, 16:58
RE: Zwave - Fibaro Motion Sensor - by baggins - 19.05.2017, 15:48
RE: Zwave - Fibaro Motion Sensor - by JMM - 18.11.2017, 16:02
RE: Zwave - Fibaro Motion Sensor - by ewatt - 14.03.2018, 09:54
RE: Zwave - Fibaro Motion Sensor - by Daniel - 14.03.2018, 10:26
RE: Zwave - Fibaro Motion Sensor - by JMM - 14.03.2018, 11:27
RE: Zwave - Fibaro Motion Sensor - by ewatt - 14.03.2018, 12:16
RE: Zwave - Fibaro Motion Sensor - by Daniel - 14.03.2018, 11:39
RE: Zwave - Fibaro Motion Sensor - by Igori - 28.01.2020, 13:19
RE: Zwave - Fibaro Motion Sensor - by Daniel - 28.01.2020, 13:51
RE: Zwave - Fibaro Motion Sensor - by Igori - 28.01.2020, 15:05
RE: Zwave - Fibaro Motion Sensor - by Daniel - 28.01.2020, 15:13
RE: Zwave - Fibaro Motion Sensor - by Igori - 29.01.2020, 17:14
