Username in visu
Only solution i know is by using a .lp file (in sample i named it user.lp) with this content:
<?     require('apps')     clientuser = request.username or 'anonymous'     print(clientuser) ?>
Create a text object with custom class 'username' , enter a random text to position the element and add it to your visu.
Add this to custom css:
.username {    display: none; }
Enable password for user folder if you add the .lp file to the user folder (otherwise it shows 'anonymous') and put this into your custom javaScript:
$(function(){   var xhttp = new XMLHttpRequest();   xhttp.onreadystatechange = function() {   if (xhttp.readyState == 4 && xhttp.status == 200) {      var res = xhttp.responseText;      if (typeof(res) !== "undefined" && res !== null){         var UpperCaseRes = res.charAt(0).toUpperCase() + res.slice(1);        $(".username").html(UpperCaseRes);        $(".username").css("display","initial");      }    }   };   xhttp.open("GET", "/user/user.lp", true);   xhttp.send(); });
Username in visu - by Thomas - 16.10.2017, 16:34
RE: Username in visu - by Erwin van der Zwart - 16.10.2017, 17:56
RE: Username in visu - by Thomas - 17.10.2017, 09:27
RE: Username in visu - by Thomas - 17.10.2017, 12:10
RE: Username in visu - by Erwin van der Zwart - 17.10.2017, 14:56
RE: Username in visu - by JohnTH - 05.02.2020, 11:22
RE: Username in visu - by admin - 05.02.2020, 12:06
RE: Username in visu - by JohnTH - 11.02.2020, 06:46
RE: Username in visu - by admin - 11.02.2020, 07:47
RE: Username in visu - by JohnTH - 11.02.2020, 10:53
RE: Username in visu - by admin - 11.02.2020, 10:56
RE: Username in visu - by JohnTH - 11.02.2020, 11:28
