EnOcean profiles supported in LM
(26.11.2015, 07:13)admin Wrote: Try this with RAW 4-byte profile (first, not the split one), though I'm not sure about contents of byte 0, try setting it to 0x0A if it does not work.
-- dimming b3 = 0x02 -- dimmer value [0..100] b2 = event.getvalue() -- ramp time in seconds b1 = 1 -- data telegram, absolute value, store final b0 = 0x0A res = bit.bor(  bit.lshift(b3, 24),  bit.lshift(b2, 16),  bit.lshift(b1, 8),  b0 ) grp.write('1/1/1', res, dt.uint32)
Added this as event-based script to the object but I get this error:
event-Event for 1/1/3 26.11.2015 21:40:29
Line 11: attempt to index global '  bit' (a nil value)
Am I doing something wrong?
Writing it like this seem to make the error go away:
-- dimming b3 = 0x02 -- dimmer value [0..100] b2 = event.getvalue() -- ramp time in seconds b1 = 1 -- data telegram, absolute value, store final b0 = 0x0A a3 = bit.lshift(b3, 24) a2 = bit.lshift(b2, 16) a1 = bit.lshift(b1, 8) res = bit.bor(a3,a2,a1,b0) grp.write('1/1/5', res, dt.uint32)
Then it is just to make this work with the dimmer. Will get back with the result.
Thanks for the help so far!
EnOcean profiles supported in LM - by edgars - 09.11.2015, 11:03
RE: EnOcean profiles supported in LM - by jorgenbl - 26.11.2015, 20:44
