29.10.2017, 17:20
(29.10.2017, 11:28)Igor68 Wrote: Hi, I have everything worked well with the previous version Voice Config. I updated it and now the Voice config does not work !!! What can be wrong? I have an LM4-Lite
After testing the previous version we came to conclusion that it is not good enough. When you wanted to Turn on lights for 1bit object you would use value 1 but when you would like to turn on 1 byte object you should use 255. Another example if you want to increment lights by 10 and you also want to increment temperature by 1. Such operations were not possible in previous version. We rebuild the app again to make it much more flexible. Unfortunately we had to brake backward compatibility due to this. Only few people downloaded the app and you were one of them.
Sorry for this but from now we will keep backward compatibility.
Please set it up again.
