Visualization on Failure
What brand DALI gateway (GW) do you use? If you use our MTN6725-0001 then you can connect it to IP and add the used IP address in the DALI app, then you can see all info from the GW. The DALI app doesn't use any ETS information. The app does not work on other brand GW's
Visualization on Failure - by Mrinj - 06.12.2017, 07:53
RE: Visualization on Failure - by Mrinj - 06.12.2017, 09:00
RE: Visualization on Failure - by Erwin van der Zwart - 06.12.2017, 09:27
RE: Visualization on Failure - by Mrinj - 06.12.2017, 09:44
RE: Visualization on Failure - by Mrinj - 07.12.2017, 07:59
RE: Visualization on Failure - by Mrinj - 09.12.2017, 09:35
RE: Visualization on Failure - by Mrinj - 10.12.2017, 11:29
RE: Visualization on Failure - by FatMax - 22.02.2018, 10:42
RE: Visualization on Failure - by FatMax - 22.02.2018, 14:58
RE: Visualization on Failure - by admin - 05.03.2024, 10:50
RE: Visualization on Failure - by admin - 05.03.2024, 12:50
RE: Visualization on Failure - by admin - 06.03.2024, 11:27
