31.01.2018, 11:26
(30.01.2018, 21:29)Jørn Wrote: In the co2/humidity/temp widget, it seems that only 1-byte values are accepted, this is a problem as my humidity values are in 2-byte, do i need to convert them with a script myself, or could you add this`?
Dimmer vertical widget statuses does not seem to work`?
Humidity this is value form 0 to 100% it should be 1byte, please use script to convert.
I will check the vertical dimmer.
