setup modbus tcp slave
thanks for all answers!
So if want to read out the outdoortemp ga 0/1/0 (2 byte float value), to the modbus, should i type in to the coil mapping or register mapping?
Is there anything more i have to change except the ip-adress port, slavenumber ?
-- list of coil mapping, starting from 0
coils = { '1/1/1', '1/1/2' }
-- list of register mapping, starting from 0
registers = { '2/2/2', '3/3/3' }
-- list of register data types, element count must match registers table
regdt = { dt.int8, dt.uint16 }
setup modbus tcp slave - by Patrik1985 - 12.02.2018, 07:24
RE: setup modbus tcp slave - by Daniel - 12.02.2018, 09:31
RE: setup modbus tcp slave - by Patrik1985 - 12.02.2018, 09:50
RE: setup modbus tcp slave - by Daniel - 12.02.2018, 10:13
RE: setup modbus tcp slave - by admin - 12.02.2018, 10:32
RE: setup modbus tcp slave - by Patrik1985 - 12.02.2018, 11:18
RE: setup modbus tcp slave - by admin - 12.02.2018, 12:17
RE: setup modbus tcp slave - by Patrik1985 - 12.02.2018, 12:59
RE: setup modbus tcp slave - by admin - 12.02.2018, 13:01
RE: setup modbus tcp slave - by Patrik1985 - 12.02.2018, 13:16
RE: setup modbus tcp slave - by Daniel - 12.02.2018, 13:28
RE: setup modbus tcp slave - by Patrik1985 - 13.02.2018, 09:29
RE: setup modbus tcp slave - by Patrik1985 - 13.02.2018, 11:25
RE: setup modbus tcp slave - by Daniel - 13.02.2018, 11:31
RE: setup modbus tcp slave - by Patrik1985 - 13.02.2018, 11:39
RE: setup modbus tcp slave - by Daniel - 13.02.2018, 11:42
RE: setup modbus tcp slave - by Patrik1985 - 13.02.2018, 13:36
RE: setup modbus tcp slave - by buuuudzik - 01.03.2018, 08:05
RE: setup modbus tcp slave - by admin - 01.03.2018, 08:20
RE: setup modbus tcp slave - by buuuudzik - 01.03.2018, 08:45
RE: setup modbus tcp slave - by admin - 01.03.2018, 11:11
RE: setup modbus tcp slave - by fabiorusco - 07.05.2018, 10:28
RE: setup modbus tcp slave - by admin - 07.05.2018, 11:30
RE: setup modbus tcp slave - by fabiorusco - 09.05.2018, 08:12
RE: setup modbus tcp slave - by admin - 09.05.2018, 08:30
RE: setup modbus tcp slave - by fabiorusco - 09.05.2018, 17:28
