Easy and fast way to make many similar Rooms in Visualization. Copy of rooms
Thanks to Daniel i, I managed to create this script to Copy Rooms in Visualization, and automatically reorganize the Groupaddresses in the new rooms. This is greatly redusing the timeconsumtion in setup.
Step 1
is to organize the groupaddress structure. For the example under, we have to use the following structure,
MainGroup = Action --> Like 6 is Temperature, 2 is Light on/Off etc..
MiddleGroup = Floor
SubGroup  = Room
This give us 6/2/3 is Temperature in room 3 in the 2 floor.
and 2/2/3 is light on/off in the same room
4/2/3 is heat-drive, same room
Step 2
Make the Visualization for the first room.
Use the proper Group-addresses and organize it the way all rooms need to look.
Use this as a default.
In Vis. Structure, make several copies of this room.
IMPORTANT Name the Copy: Copy (MiddleGroup)(Subgroup)
We then have the following rooms in Vis Structure:
Copy 201
Copy 202
Room 203
Copy 204
Copy 213
Copy 240
Copy 201
Step 3
Run the script under from resident. (Note: script will auto-disable itself at the end, since this only need to run once.)
Script will change all objects in all Rooms named: "Copy*" to be linked to the corresponding Middle and subgroup, leaving Main-group unchanged.
This will change hundreds of group-addresses in seconds.
Step 4
After Script, in Vis. Structure, change name to wanted name, and add PIN codes etc. as needed. In Visualization edit all Labels, and texts as wanted (like heading for room-name)
Script to be inserted in resident:
--This script will automatically replace middle group and group in KNX addres based on room number. --For example if room name is Copy 315 then all object on this plan will have addressing X/3/15--- --Script will replace only roome which name will start from 'roomSearch' parameter. This can be modified as many times as it is needed. --Be carefull, wrongly used can destroy whole project. Always make buckup before running the script --Script will disable itself after it is finished. roomSearch = 'Copy' -- set constant name which will be starting plan name. ---------------------------------------------------------------------------------------------------------- -------------------------------DO NOT CHANGE ANYTHING BELOW THIS LINE------------------------------------- roomSearch = roomSearch..'%' dbfloors = db:getall('SELECT id, name FROM visfloors WHERE name LIKE '..'"'..roomSearch..'"'..' ') for _, floorsData in ipairs(dbfloors) do  floorID  = floorsData.id  roomName = floorsData.name  roomNumber = string.match(roomName, "%d+")  middleGroup = tonumber(string.sub(roomNumber, 1,1))  group = tonumber(string.sub(roomNumber, 2, 3))    dbobjects = db:getall('SELECT id, type, object, statusobject FROM visobjects WHERE floor = ' .. floorID .. ' AND type < "2"  ')    for _, objectData in ipairs(dbobjects) do        mainGroupControl = bit.rshift(objectData.object, 11)    mainGroupStatus = bit.rshift(objectData.statusobject, 11)      oldControlAddress = objectData.object  oldStatusAddress = objectData.statusobject  currentRow = objectData.id  newControlAddress = ((mainGroupControl * 2048) + (middleGroup * 256) + group)  newStatusAddress = ((mainGroupStatus * 2048) + (middleGroup * 256) + group)   --  log('oldControlAddress= '..tostring(oldControlAddress)..', currentRow= '..tostring(currentRow)..', newControlAddress= ' ..tostring(newControlAddress)..', newStatusAddress= ' ..tostring(newStatusAddress) )  db:update('visobjects', { object = newControlAddress }, { id = currentRow })  if (oldControlAddress == oldStatusAddress) then --if no status object selected main object must be used  db:update('visobjects', { statusobject = newControlAddress }, { id = currentRow })     else  db:update('visobjects', { statusobject = newStatusAddress }, { id = currentRow })     end      end       end   log('update finished') script.disable(_SCRIPTNAME)
PS:
This script is only for Subgroup 0-99 (room X00 to X99)
If 0-255 is needed, change room-names to Copy X001 to X255
And change in script:
into:
group = tonumber(string.sub(roomNumber, 2, 4))
PPS:
Allthoug I myself have had a lot off fault free success with this:
This scrips is messing with the database in LM, (as always) make sure to Backup before you test it, just in case we screw it up
Never underestimate the dark power of Scripting
Easy and fast way to make many similar Rooms in Visualization. Copy of rooms - by DarthPaul - 23.02.2018, 08:37
