28.02.2018, 08:34
(28.02.2018, 08:29)AEK Wrote:Notifications are sent trough google services regardless if you are on local network or on 4G. This must be something with your internet connection.(28.02.2018, 07:52)Daniel. Wrote: Hi
Apps are not hardware dependent. It must be something in settings.
Common mistake is to first install app on smartphone and add LM and then later install cloud app on to LM. Cloud app must be running on LM before you add LM to your smartphone app. You can disable notifications and save, then enable again and save. Also make sure you are logged in to cloud in cloud app.
this helps.
but cloud app was installed first, logic machine app for android was installed second
now we have another problem:
we recive pushs only when android in the same wifi network as LM.
when we switching to 4g network we don't get pushs. is there any way to find out where is problem.
one more thing. android app don't find any device in local network (even LM). so everytime we start the app it says "can't connect to LM". lm's local ip is set in settings
could it be problem in router settings?
Do you use Voice control?
