28.02.2018, 11:53
(28.02.2018, 11:40)Daniel. Wrote:(28.02.2018, 11:29)JoseJimenez94 Wrote: Thank you!
But now I have a problem. When i try to modify a widget and upload then, nothing happens.
I have tried to modify just the tittle and when i upload the .tar.gz, the widget doesn't appear (error message doesn't appear neither).
i don't understand what is happens.
I just want to do a widget of two switches (a general switch for one detector and a switch for one light, in parallel) on/off (with their status), but there is no way to get it
Or maybe there is some way to put two different widgets together?
Make sure that you use widget ID as Key and it is unique.
Im sure. I just change the tittle (in objects), i dont change Key or nothing more. I use the same widget ID as key.
