Gardena smart
Anyone already linked a Gardena Smart gateway?
Here my first code to read a Sensor and write the moisturelevel and batterylevel.
function getData()   https = require 'ssl.https'   require('json')   socket.http.TIMEOUT = 5    local cUsername = 'email@abc.com'  local cPassword = 'password'     -- get session info   local cBody = '{"sessions":{"email":"' .. cUsername .. '","password":"' .. cPassword ..'"}}'   local cReq = {}   local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/sessions'   result1 = https.request({       url = cUrl,       method = 'POST',       headers = {         ['content-length'] = #cBody,         ['content-type'] = 'application/json'       },       source = ltn12.source.string(cBody),       sink = ltn12.sink.table(cReq)   })   if result1 then     --log(cReq)     cReq = table.concat(cReq)     cReq = json.pdecode(cReq)     if cReq then       --log(cReq)       token = cReq.sessions.token       user_id = cReq.sessions.user_id     end   end   -- get location info   local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/locations/?user_id=' .. user_id   result2 = https.request({       url = cUrl,       method = 'GET',       headers = {         ['content-type'] = 'application/json',         ['X-Session'] = token       },       sink = ltn12.sink.table(cReq)   })   if result2 then     --log(cReq)     cReq = table.concat(cReq)     cReq = json.pdecode(cReq)     if cReq then       --log(cReq)       local loc_name = cReq.locations[1].name       loc_id = cReq.locations[1].id     end   end   -- get device info   local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/devices?locationId=' .. loc_id   result3 = https.request({       url = cUrl,       method = 'GET',       headers = {         ['content-type'] = 'application/json',         ['X-Session'] = token       },       sink = ltn12.sink.table(cReq)   })   if result3 then     --log(cReq)     cReq = table.concat(cReq)     cReq = json.pdecode(cReq)     if cReq then       --log(cReq)       local dName = cReq.devices[1].name       for k,v in pairs(cReq.devices) do         --log(v)         --log("Found the following GARDENA "..v.category)         --log("Name: "..v.name)          --log("Identifier: "..v.id)         -- gateway         if (v.category == "gateway") then          -- sensor         elseif (v.category == "sensor") then           for a, b in pairs(v.abilities) do             for c, d in pairs(b.properties) do               --log(d.name)               --log(d.value)               if (d.name == 'last_time_online') then                 --check = tostring(d.value)               elseif (d.name == 'humidity') then                 grp.write('1/1/1', tonumber(d.value))               elseif (d.name == 'level') then                  grp.write('1/1/2', tonumber(d.value))               end             end           end         -- onbekend apparaat         else           log('onbekend gardena apparaat: '..v.category)         end       end     end   end end
Gardena smart - by gjniewenhuijse - 23.04.2018, 07:12
RE: Gardena smart - by admin - 25.04.2018, 06:45
RE: Gardena smart - by gjniewenhuijse - 26.04.2018, 06:24
RE: Gardena smart - by Firechief - 24.05.2020, 16:22
RE: Gardena smart - by Joep - 31.07.2023, 15:01
