read failed: Illegal data address
Thanks! uint32 worked for reading.
Now to the bigger problem, scripting. I searched the forums and found a similar thread regarding writing a bit, but I'm not sure I understand it? I have edited it to suit me.
Must I first set mode, before I send either of the bool KNX telegrams? This register contains 32 bits, no need  store all the other bits?
But I'm not convinced I have done it right, valuue+512=512+512 and so on?
How will the Bool KNX objects be resetted to 0? Otherwise they will be 1 next time the script runs and perhaps set the UPS in ByPass by error?
-- 0=set bit 0, 1 -- 1=set bit 1, 2 -- 2=set bit 2, 4 -- 3=set bit 3, 8 -- 4=set bit 4, 16 -- 5=set bit 5, 32 -- 6=set bit 6, 64 -- 7=set bit 7, 128 -- 8=set bit 8, 256 -- 9=set bit 9, 512 mode = grp.getvalue('1/1/1') -- 1-byte unsigned integer OutputBypass = grp.getvalue('6/1/0') -- boolean OutputOnline = grp.getvalue('6/1/1') -- boolean ClearFaults = grp.getvalue('6/1/2') -- boolean if mode == 4 then   value = 16 elseif mode == 5 then   value = 32 elseif mode == 9 then   value = 512 end if OutputBypass then   value = value + 16 -- Bit 4 end if OutputOnline then   value = value + 32 -- Bit 5 end if ClearFaults then   value = value + 512 -- Bit 9 end log(value)
read failed: Illegal data address - by sx3 - 08.05.2018, 19:41
RE: read failed: Illegal data address - by sx3 - 10.05.2018, 07:22
