Spacelynk Cpu load high
looks like there is multiple send of telegram (with routing number wich increase). For example a telegram from a temperature sensor is send on the bus. But when i log, i see it more than 5 time.
The line 1 is with Schneider Ip router
The line 2 is with Schneider Ip router
The Spacelynk is on line1, but also with IP interface (multicast adress are the same than the 2 Ip router). I will try to put a different multicast Ip adress to test.
SE ECO EXPERT
Spacelynk Cpu load high - by domotiqa - 28.05.2018, 08:49
RE: Spacelynk Cpu load high - by admin - 28.05.2018, 09:44
RE: Spacelynk Cpu load high - by domotiqa - 28.05.2018, 11:31
RE: Spacelynk Cpu load high - by admin - 28.05.2018, 11:55
RE: Spacelynk Cpu load high - by domotiqa - 29.05.2018, 07:41
RE: Spacelynk Cpu load high - by Daniel - 29.05.2018, 07:45
RE: Spacelynk Cpu load high - by domotiqa - 29.05.2018, 07:53
RE: Spacelynk Cpu load high - by Daniel - 29.05.2018, 08:01
RE: Spacelynk Cpu load high - by domotiqa - 29.05.2018, 09:07
RE: Spacelynk Cpu load high - by Daniel - 29.05.2018, 09:15
RE: Spacelynk Cpu load high - by equalizer - 04.12.2018, 13:38
RE: Spacelynk Cpu load high - by domotiqa - 04.12.2018, 15:18
