Spacelynk Cpu load high
The Ip feature is needed to program Product when away from the customer building (I use script to enable/disable).
Looks like it's working when changing multicast adress. The standar one is 224.0.23.12. So i imagine that the Spacelynk see it on the Tp part, and also on the multicast Ip adress, then maybe try to send it again on Multicast...
I change it on spacelynk:
224.0.23.13
I let the both Ip router on 224.0.23.12.
Now I have telegram send only one on the bus monitor and i know can program with Spacelynk (I couldn't before, timeout error).
The second option I had what to disable Tp feature, and only use Ip with both router.
What do you think about this study case
SE ECO EXPERT
Spacelynk Cpu load high - by domotiqa - 28.05.2018, 08:49
RE: Spacelynk Cpu load high - by admin - 28.05.2018, 09:44
RE: Spacelynk Cpu load high - by domotiqa - 28.05.2018, 11:31
RE: Spacelynk Cpu load high - by admin - 28.05.2018, 11:55
RE: Spacelynk Cpu load high - by domotiqa - 29.05.2018, 07:41
RE: Spacelynk Cpu load high - by Daniel - 29.05.2018, 07:45
RE: Spacelynk Cpu load high - by domotiqa - 29.05.2018, 07:53
RE: Spacelynk Cpu load high - by Daniel - 29.05.2018, 08:01
RE: Spacelynk Cpu load high - by domotiqa - 29.05.2018, 09:07
RE: Spacelynk Cpu load high - by Daniel - 29.05.2018, 09:15
RE: Spacelynk Cpu load high - by equalizer - 04.12.2018, 13:38
RE: Spacelynk Cpu load high - by domotiqa - 04.12.2018, 15:18
