EnOcean profiles supported in LM
Threads: 0
29.01.2016, 19:43
(This post was last modified: 29.01.2016, 20:10 by zubin.)
[attachment=113 Wrote:jorgenbl pid='704' dateline='1450642519']
Hello Jørgen,
I hope your doing fine.
To let you know,i got through the dimming, but i have an further issue on this which is as follows :
1. Whenever i operate the Eltako Dimmer from Logic Machine i.e simulate the value its dim successfully and also i receive back the feedback dimming value, but when i operate from Eltako Wireless Switch FT4 the Eltako Dimmer operates accordingly and sends the dimming value back but after sometime again Logic Machine writes the earlier forced value. i hope you got my point. so this is a mismatch, i want to operate Dimmer simultaneously via both Eltako Wireless Switch and Logic Machine, so value has to be updated in Logic Machine when operated from Wireless Switch which updates into feedback Object but again after some time the previously created 1 byte unsigned Object re-writes the last value.so let me know a solution to avoid this conflict.
2. Also let me know your teach in telegram structure . like when i used your mention code for teachin telegram i get code "00-00-00-00" which Eltako FUD dosen't accept, so i change your code to "02-00-00-00"(b3-b2-b1-b0), Please confirm is this right, its working for Dimming but for that i taught it in position of GFVS PC/PCT on rotary switch.So let me know your Teachin Telegram structure when you use your code.
You can refer two attached image for details:
1.Teach in telegram received when i use your script.
2.Teach in telegram received when i used my modified script - 02-00-00-00
Looking forward to your positive reply.
(09.11.2015, 11:03)Hello Edgars, Wrote: Are you planning to add following profiles :
1. A5-12-01 - ENERGY KWH MONITORING.
2. A5-20-03 - WIRELESS BI-DIR ACTUATOR (FOR % FEEDBACK VISUALIZATION)
Waiting for your positive reply.
| Messages In This Thread |
RE: EnOcean profiles supported in LM - by zubin - 29.01.2016, 19:43
