19.06.2018, 15:13
(19.06.2018, 13:08)bmodeco Wrote: I still find that the best visu/touchscreen is an ipad. It allows for easy web/interface viewing and you can also use it to control other things: check agenda, weather, control homekit/siri, hue, sonos, etc... I have a wallmounted ipad on each floor. Also if you have a mobile ipad or iphone you use in the house it can also be used as a client and used to answer the doorcall.
Most customers are also familiar with an ipad. Latest generation is only 360 euro here in Belgium - sometimes you can find it even with 10% discount...or use a refurbished unit/older generation...
As for SIP/VOIP: I am using the free linphone as sip-server, on the ipad/iphone i am using Bria Mobile as a client. I am currently using an axis-camera at my front door which supports SIP - I trigger this securitycam (also registers all video) to make a VOIP call when somebody rings my doorbell and my ipad and/or my iphone start ringing - I can answer/talk and see video/audio.
When using a doorstation it should be possible to program the SIP-serverinfo for linphone, etc in the interface.
Great solution. Do you use wall mounts with charger? how is the life time of the batteries after a while?
BR Even Sundgot.
