20.06.2018, 15:21
(19.06.2018, 16:41)bmodeco Wrote:(19.06.2018, 15:13)Evens Wrote:(19.06.2018, 13:08)bmodeco Wrote: I still find that the best visu/touchscreen is an ipad. It allows for easy web/interface viewing and you can also use it to control other things: check agenda, weather, control homekit/siri, hue, sonos, etc... I have a wallmounted ipad on each floor. Also if you have a mobile ipad or iphone you use in the house it can also be used as a client and used to answer the doorcall.
Most customers are also familiar with an ipad. Latest generation is only 360 euro here in Belgium - sometimes you can find it even with 10% discount...or use a refurbished unit/older generation...
As for SIP/VOIP: I am using the free linphone as sip-server, on the ipad/iphone i am using Bria Mobile as a client. I am currently using an axis-camera at my front door which supports SIP - I trigger this securitycam (also registers all video) to make a VOIP call when somebody rings my doorbell and my ipad and/or my iphone start ringing - I can answer/talk and see video/audio.
When using a doorstation it should be possible to program the SIP-serverinfo for linphone, etc in the interface.
Great solution. Do you use wall mounts with charger? how is the life time of the batteries after a while?
BR Even Sundgot.
I used the sdock Fix as a mount.
For power I used a POE-converter since i already had a utp-cable available but you can use a 230V-usb adapter also and place it behind the dock in the wall.
I don't care about the battery-life since i never remove them from the wall.
Basalte has a nice (but expensive) dock that snaps the frame with ipad on the wall and charges it. You can easily (magnetic) remove the ipad with thin frame from the wall and use it elsewhere. This way you can move it around to different floor/rooms/etc...
And you can rotate the ipad...it charges through the magnetic connections - https://www.basalte.be/en/news/60/basalt...-dock-ever
If you have a client that doesn' mind spending the money...
Nice products, seems like a nice solution.
